05-17-2017
04:13 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-17-2017
04:13 AM
in the Quick select options (see Image)
in this example I used the Wildcard Match option for Numeric Match (#) Note the sequence in the value field the 1 did not get selected but everything after the apostrophe is
so depending on your needs your filters will vary.
once you have worked out your selection sets you can then place things on their respective layers for easier sorting and coloring, if you choose to take that route.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
