john.vellek
en respuesta a: Anonymous
HI @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Typically, you are not going to be able to open and use a Viewbase Layout that was created in a newer release. Even if the file format is the same version, the Inventor engine associated with each version of AutoCAD changes and are not backward compatible.
So, only go to the newest version if that is where the data will remain.
Please let me know if you have additional questions on this issue.
John Vellek
