318 Vistas, 4 Respuestas
page setup for autocad 2017
can i print a page that is longer than A0 in AutoCad 2017? because from 2015 version i was able to and now i am trying to customise a page that is longer than 1180mm in length but the custom property is greyed out.
previously i was able to set a page that i want like if i want 2400mm x 830mm i could create it now i cannot do that is that option removed from autocad or something?
pendean
en respuesta a: Anonymous
Same method you did in 2015 (custom page size if your plotter allows for it) is the method you would use in 2017.
It has nothing to do with AutoCAD.
So, what are you plotting to?
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
 Please tell me the type of output (printer) device that you are using and which driver. Does this device have multiple rolls? If so, which one do you want to plot this size to?
I would like to see your PC3 file to see if it works once I install the printer driver. Can you attach it to a post for me? Also, possibly attach a sample drawing file?
John Vellek
john.vellek
Hi @Anonymous,
Have you resolved your issue? I am happy to help if you still need assistance.
John Vellek
en respuesta a: john.vellek
yes thanks the problem was the drivers for the plotter ,so i downloaded the T1200 drivers and it worked.
