Ranjit_Singh2
en respuesta a: Anonymous
Welcome to the forums!
if the numbers are all in the same space (model space, paper space) then select the necessary elements and change color in properties window. If you need to automate it, assuming it's too much work to select them, just because they are scattered all over or maybe even in different layouts, then you need to use lisp. Post a thread in the LISP forum here with a sample drawing.
