Alfred.NESWADBA
en respuesta a: Anonymous
>> an model airplane fuselage of about 700mm wide with the intention to poster print
>> this on A4 or A3 landscape paper. [...]
AutoCAD does not have a function for poster print, you have to create your layouts with viewports by yourself.
>> I do need the drawing printed out on a 1:1 scale
To define the viewports scale select the viewport and chose the scale you need:
After that copy your layout. For each copy you can then use command _-PAN and pan the content of the viewport by the width or height of the viewport.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
