davorkl
3580 Vistas, 2 Respuestas
Can't zoom in more than displayed
Greetings,
I have an issue with zooming into the drawing more than it is displayed (older Acad versions give "Already zoomed in as far as possible, Acad 2016 and newer just regenerate exact same position every time).
Regen, Drawing Limits, moving UCS, setting new view - nothing helps and this prevents me from drawing a profile line.
I actually know where the issue comes from - we are using third party software for road design and so it happens that this particular profile gets drawn at ridiculous Y coordinate. It is a glitch on the programmers side and a fix is quite straight forward from their side - simply change the position where the profile view gets drawn, which should be far more close to coordinate system origin or by the plan view (not included in dwg that I have attached).
But in the meantime - if I could somehow persuade this DWG in the attachment to allow me to zoom in further, I would be super happy. Any suggestion is more than welcome, except for one - since the position is generated by this third party program, I cannot simply move the profile view closer to coordinate system origin. That would not help me as this program uses its own set of commands for drawing profile and it unfortunately expects the profile to be where it is designated by it.
So, thank you for any possible other advice.
