- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Properties Box Not Working
My properties dialog box was very helpful in 2012 which enabled chanegs to colors, layers, text sized, polyline widths, and much more.
With my Autocad 2014 SP1 corporate Microsoft System Center 2012 install the properties box appears but does not reflect the element selected nor allow changes (i.e., does not work). I removed and reinstalled Autocad 2014 SP1 but the issue remains.
Any specific experiences and remedies by others besides reinstalling the software?
Thank you.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I tried removing and then reinstalling the software, but the properties box still does not work.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I removed Acad 2014. I reinstalled with virus off. I had no other conflicting programs open. Still, properties box shows but does not change/reflect item selected.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
No. Just selecting 1 item, hopeing to be able to change properties using the dialog box (e.g., a text, a line), which the box still does nto adjust to the type of item selected nor enable a change.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Are you running an add-on to AutoCAD?
Is DEMANDLOAD set to 3?
When PROPERTIES is up on screen and you type OPMSTATE, does AutoCAD show the setting as 1?
Can you see the object properties in the RIBBON (Home Tab, Properties Panel) if you select any objects?
As a test, if you log into Windows as another user, does the problem persist?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I did not ask for any add ons.
DEMANDLOAD = 3 OK
OPMSTATE = 1 OK
in Classic Mode the properties box does not work.
In ribbon mode the selected item will not change properties even when scrolling to another option.
Isolated so will much later try logging on with another user.
As associate who downloaded Acad 2014 SP1 the same way as I had no issues with the Properties box.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
