cadffm
en respuesta a: Anonymous
In 2018 it works fine.
Do you use the "PDF Option" of AutoCAD, or do you use your own PDF driver?
Because in the foreign PDF driver could be also the information "after create display" be set.
If you use Acad-PDF, then give your exact version, maybe someone can test with this version and Servicepack. VERNUM
Sebastian
