05-10-2017
10:32 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-10-2017
10:32 PM
Hello Gabriel,
Using a Flatshot in newer version of AutoCAD (2015) gives same results as in Your case.
I believe this has something to do with how Your solid was created. I'm not sure if it was drawn in AutoCAD or imported, but I'm sure this didn't initially consist of just Line + Arc elements (or wasn't recognized as such), because then the created blocks would be exploded to same elements.
There is something like spline- to polyline conversion, but this won't do any good in Your case. Unfortunately, I'd recommend redrawing the object if You need those lines.
Kind Regards,
Pawel
