1051 Vistas, 3 Respuestas
CAD to CNC
Hello AutoCAD friends!
I am writing about a obstacle I know can be overcome simply from people like You! Currently at work I am using TurboCAD Professional 2015. I am using the 2D layouts to be sent out to SCMI CNC. It only runs XYZ axis, nothing more nothing less. The CNC only reads DXF formatting.The problem I  am trying to solve is getting a semi-sphere (half a basketball shape) cut. I understand that the product can only be cut to only a semi-sphere on the X + Y axis. Is there a way I can make relief cut to make detailed 3D products?  For an example 2.5 dimension products such as Michael Jordan slam dunking, your face cut into a wood block, ect. That is what I need to figure out.
Thank You AutoCAD Community,
Stephen C
Etiquetas (7)
pendean
en respuesta a: Anonymous
>>>...I am using TurboCAD Professional 2015...<<<
TurboCAD support is at another company website over here https://www.turbocad.com/content/category/Support
Their Public support forums are here http://forums.turbocad.com/
john.vellek
Hi @Anonymous,
Are you intending to move to AutoCAD to do this? AutoCAD will allow you to do 3D modeling which can be exported to dxf as well as a variety of other formats.
Do you have a sample drawing to show what you want to create?  If you are only doing this in TurboCAD then I am not going to be much help as I haven't used the product in at least a decade.
Perhaps you can show a sample and also download a trial version of AutoCAD to experiment with its capabilities.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
