720 Vistas, 5 Respuestas
CREATING AN ISOLATED ELEVATION
I have done this in the past, but man it has been years.
I have a floorplan that I am working with. I want to create an elevation view of one wall without everything else in the viewport.
There is a command  to point to a certain wall or objects, and only those objects are visible, other than using the new Layout Base View.
Anyone remember this one?
Thanks in Advance !!!
James
en respuesta a: Anonymous
AutoCad 2017 is my current software
I use a routine that uses the DVIEW CLIP function to quickly cut clipped views through 3D models.
Search for DVP.LSP, I've posted it a couple of times lately.
john.vellek
HI @Anonymous,
Are you trying to use LayISO or HIDEOBJECTS for this workflow? Or Perhaps VPLAYER Freeze?
3DClip might also be useful.
John Vellek
imadHabash
maybe MVSETUP will help...
Imad Habash
As john.vellek points out LAYISO or maybe _ISOLATEOBJECTS, Layiso will isolate by layer while _ISOLATEOBJECTS will isolate by object.
3DCLIP will place cutting planes wither side of the 3D wall to provide a true elevation of the wall.
The DVP.lsp I mentioned (find it HERE) is a fast way to set those 3DCLIPping planes.  Watch the video, there no sound, but it shows selecting two points in one view to locate the clipping plane and a third pick for the viewport in which the clipped view will land.
