- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
help, no ribbon
when i start auto cad i can only use command bar to draw, there is no ribbon up top. i cant acess anything by mouse and I cant find where to turn them on. how do i turn on the ribbon up top, like in microsoft word
i have autocad 2016 student version, same as my college, but at school they have the ribbon, since first day of class 3 months ago
please help, i cant figure this out
attached pic of screenshot,
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You are in switched to layout. For Going back to model space click in the bottom left tab labeled model. Check the image
Enter command RIBBON to see you Ribbon Toolbar.
Cheers,
Vinay Vijayakumaran ![]()
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
start command _RIBBON, that should bring you the ribbons to the screen.
If that does not work you can try to reset the AutoCAD profile as described >>>here<<<.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
your current workspace is set to Blank1, which is not a default one from autodesk, possibly something you created. if you click on the down arrow to the right of the area in the QAT at the top left of your screen, you should be able to get to the workspace Drafting and Annotation, which should get you back to the original layout, if the ribbon was closed for that workspace, you can follow Alfred's advice and use RIBBON to get it to open back up.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
