- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
When working on a plan, I pick a command and a grey list of tool tips appears. It will block the area I am working on and I can't select what is beneath it. I zoom in and out to get around it, but that is inconvenient. How can I toggle this on and off? Thanks a bunch.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
HI
As we don't have your file to test Please tell us
1-is it happening alwasye on every drawing or in spatial file?
2-is it happening on a new drawings ?
3-did you tried your file in other computers?
if you can send a screen capture from your display
Good Luck
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You could be seeing Dynamic Input. Turn it off at the command line with DYNMODE = 0 or make the change from the Status Bar or Drafting Settings. A snapshot of what you are seeing would help us to help you.
Nancy
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks for trying to help me. Yes it does happen on every plan and on every computer. I'm not sure tool tip is the right term. Here is an example:
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks for trying to help me on this. I don't think I have the right term for my problem.
here is an example:
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
HI,
Q:is there certain command that this Tip appeared under?
maybe ROLLOVERTIPS system variable will help if you change it to ( 0 ) Zero.
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
What version of ACAD are you using and are you using a computer with 4k resolution by any chance? Does any of this help:
https://forums.autodesk.com/t5/autocad-forum/4k-display-problem/m-p/6784995#M157194
Nancy
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@Anonymous
This gray bar is your Commandline history showing.
Try docking your commandline at the bottom of your screen so it shows 3 lines of text instead of the 1 in the floating commandline.
Hope this helps.
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Good thought, but I tried ROLLOVERTIPS and the grey text area is still there. The information it gives is like a status update of what you are doing or have just done.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@cadacerense wrote:@Anonymous
Hope this helps.
You gave me something to work with. I did a search on turning off commandline history and found that the variable CLIPROMPTLINES set to 0 turns this off. Thanks for directing me!!
