en respuesta a: Anonymous
Do not move the UCS, move the object to its appropriate coordinates.  ALL objects should be placed at their appropriate coordinates so that EVERYTHING will be in the proper location when XREF'd.  XREF's are based on World UCS, moving the UCS to display specific coordinates menas the object will not reside in the proper locations when used as an XREF.  Manipulating the UCS is ONLY a temporary aid to constructing components.  Get used to working n absolute coordinates and it won't be an issue later.
EDIT:
In order to MOVE the object(s), enter the MOVE command, select ALL, for a base point select the point you wish to reside at the given coordinates, and for the second point enter an asterisk (*) and then the coordinates.  The point you selected will be transformed to the coordinates you entered.
The asterisk indicates absolute "World" coordinates with or without DYNMODE active, while the @ symbol is relative to the last point selected.
