- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
i have drawn in all my lines such as insulation , dpc , breather membrane and other lines with patterns.
however when i take them over to paper space they suddenly turn absolutely massive.
does anyone know whats wrong as this is due on monday and im bricking it a little
thanks
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
HI
There is lot of reason for it.
(vport size , annotation scale ,paper size,...)
Please Send your dwg file to forum to explore more .
Good Luck
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
Ara is correct that there are too many things that can cause this to happen for a single answer to be provided. Please attach a sample file and I am happy to look at it for you.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
thanks for your replies
I've actually managed to partly solve the issue by changin PSLTSCALE from 1 to 0.
HOWEVER!
I now have to go through every drawing and redraw all the insulation lines as that's the only way it will work.
is there a short cut for this? or has it just got to be done?
thanks again
Matthew
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
HI @Anonymous,
How are the lines drawn? Are they a specific linetype? Are all the properties set to bylayer?
You could use the Action Recorder to create a macro perhaps that would change them to a different linetype.
I will need to see a drawing in order to offer more.
John Vellek
