412 Vistas, 4 Respuestas
PDF operations
Dear all,
Does AutoCAD give us opportunity to edit .PDF files like in .dwg files, for example trimming the .pdf lines, or extending them?
Thanks for the answer in advance
Best Regards,
Qulu Quliyev
imadHabash
en respuesta a: Anonymous
Hi and Welcome to AutoDesk Forum,
>> Does AutoCAD give us opportunity to edit .PDF files like in .dwg files, for example trimming the .pdf lines <<
NO ... you can't as you describe it.but you can import the pdf file as CAD segments that you can treat with and edit.read more and learn HERE page 27.also here >> Link <<  and >> Link1 << .
Good Luck..
Imad Habash
ara_neresesian
hi
 I think in 2018 you can find something see this
http://www.autodesk.com/content/dam/autodesk/www/products/autodesk-autocad/fy18/features/videos/pdf-...
but  it is depend to the source file ,all pdf can't be convert
GOOD LUCK
en respuesta a: imadHabash
Thanks for your answer. That was what I guessed.
Best Regards
Qulu Quliyev
en respuesta a: ara_neresesian
Thank you for your answer. That was what I guessed.
Best Regards,
Qulu Quliyev
