pendean
en respuesta a: v_yang84
If you had the actual font file and it was not corrupt it would look like my screenshot on the left, not your substitution on the right.
The font file your session of AUtoCAD is finding is garbage: and it may be in another folder AUtoCAd is searching before it gets to the one you think is good.
Time for a deep search on your system to delete ALL instances of the font, then replace it with a verified good one from the other computer and place it in the correct folder as noted by others. If it still does not work, you did not do a good job of finding the bad one in the AutoCAD search path.
Good luck: no other scenario will cause what you see unless you haven't restart Windows in a few moons and it's about to go south on you.
