- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Error: VLAX-LDATA-GET
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
could you provide some more specifics?
what is the third party software?
what command is being run when you get the error?
do you run other customizations beyond this 3rd party software?
does the issue happen every time you run the command or only every so often?
is there a pattern to it erroring out?
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I'm sorry you are having this issue. I would first suggest that you make sure that AutoCAD 2017 is fully patched and updated from your Account Management page.
Then I suggest creating a new user on your computer and logon with that account. Don't do any customization and see if AutoCAD runs normally.
When you remove the add-in and then do a Repair and Reset do things return to normal?
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
It isn't easy to find the exactly problem and the event who create the problem.
Problems like that are known, few vlax* function no definition, (vl-load-com) doesn't help in these situation.
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I am checking back to see if you tried the steps that I provided? I hope that they helped to track down the cause of this issue. Please add a post with your results.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
into the file itself. IMO it has nothing to do with the software.
Do a search in the customization section using the keyword
"PDI". It stands for "Purge Dictionary Items". If the key is corrupt,
you may try to remove it and let that third-party software rebuild
itself.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.![]()
