en respuesta a:
08:45 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-18-2017
08:45 AM
Hello all,
I found a block where this problem occurred which I can attach as dwg.
Fixing normal.dwg is the fixing block as it was when it was not doubled. That block has been restored from our daily backup.
Fixing doubled.dwg shows the same block one day later, you can see that there are all objects doubled and clearly an older version and a newer version of the block. They are quite different, so deleting the duplicated objects takes a lot of time.
Thanks in advance for having a look at this,
Regards
Mareike
