en respuesta a: Alfred.NESWADBA
Hi Alfred,
thanks for your answer.
  • You do have a block-in-block structure, that can sometimes be irritating
Agree. We are using blocks in blocks which can cause trouble. My best guess is that this happens when saving the block, that's why I never notice when it happens. I'm not the only one having this problem, there are a few more users affected. We are all using exactly the same set up, Hardware and Software. It started last year when we were still using AutoCAD 2012, I hoped that the problem would be solved with updating to AutoCAD 2016. Unfortunately, the problem persists.
  • You do have an application/tool/plugin running on top of AutoCAD which resets or modifies block-definitions
That was my first thought, we have custom made tools running. But these are running on I guess 200 AutoCAD installations not causing any of this trouble. We only know of 3 Users having this problem.
  • You are not up-to-date with your AutoCAD (look to _ABOUT and show us a screenshot from that dialog, without serial number if there is one)
I Hope you are looking for the screenshot attached, if not let me know. We are currently using AutoCAD 2016 SP1.
Thanks very much for your help,
Regards
Mareike
