Alfred.NESWADBA
en respuesta a: pw8154
it's great that you already found your solution! :cara_guiñando_un_ojo:
>> I think I might send something that doesn't work in my drawing,
>> but works for you (as it does if I create the profile in a new drawing)
I would like to have your drawing (erase the other entities) and not a copy of that polyline in a new drawing.
From what you tell us I agree that it might be a combination of drawing + geometry, and that can have e.g. high coordinates as reason, or something else. But again, hard to guess without having it. :cara_guiñando_un_ojo:
If you want to find the reason the feel free to upload it.
>> I have 200+ frame outlines in a drawing
Just to make sure: if that geometry objects don't intersect or touch each other, that should be done by just one command (_PEDIT with option "multiple objects).
With _BOUNDARY you have to go for each single polyline, maybe if you know the reason about when that issue happens the result is less work :cara_guiñando_un_ojo:
On the other hand .. copying all arcs and lines to a new drawing should also result in running just one single command to get it done?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
