cadffm
en respuesta a: Anonymous
You could make a nested Block:
New File with one Insert on 0,0,0 rotate0 Skale 1,1,1 with defined Attribut-Value
Add this file into the Palette, change explode propertie to YES
not exactly, but
For one block, and every inserts of the block the same data?
Than redefine the blocks and use constant attdefs or set the value by default.
For one Block, and different data of insert attributes, you can insert by a macro-tool (possible in toolpalettes too)
Example, Block with two non-constant Attributes
^C^C_INSERT;MYBLOCK;\1;1;0;Attval1;Attval2
Sebastian
