- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
>> But I can't see Service pack 1.1 for AutoCAD
Not "service pack" ... it's named "update 1.1".
And you get it either by Autodesk Desktop App or when you login to >>>manage.autodesk.com<<< ==> Product Updates and then scroll down in the list
>> It stucks a few minutes when I type command text things.
So starting the command takes long, but when it is started all is working normal?
I guess the most important question is not answered:
...have you fonts on your system created/copied/installed that differ from a default operating system setup?
Because if starting text-like command needs a long time (to start) it can be dependent on the number of installed fonts or there are paths defined which are
- not reachable any more
- are slow on network or external (cloud) paths
- are permission restricted.
Let's start with: disconnect your system from all networks, then start AutoCAD and try the text command again.
Also start command _OPTIONS ==> first tab "Files" and go through each single path and verify that it really exists.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
