Alfred.NESWADBA
en respuesta a: toznal
>> Yes I'm running AutoCAD 2017 with SP1
Then please update to "AutoCAD 2017 Update 1.1"
...and please let us know which operating system you are using.
>> It's slow on a blank new drawing as well.
Create such a new drawing with two text-objects and upload it here please.
  • First text object with a style that is based on the TXT.SHX font ==> verify if that is slow too.
  • Second text object with a style you are used to have.
>> But It works so slow!
What exactly is slow? Starting the command, entering text, changing text properties, moving the text, ...
If you can create a screencast (>>>Autodesk Screencast<<< is free) then we hopefully see what's happening exactly.
Please start command _GRAPHICSCONFIG and show us a screenshot from that dialog.
As a first guess: have you fonts on your system created/copied/installed that differ from a default operating system setup?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
