en respuesta a: john.vellek
Hi @john.vellek,
I typically do not include pipe cut lengths for our rail in out shop drawings, we provide overall dimensions and post to post center-line dimensions and our shop creates the cut sheet for the pipe according to what fittings are going to be used to connect the pipe. Our shop superintendent usually breaks it down, he plugs his information into a spreadsheet he created over the years that gives him the over all cut length. He has to plug in the radius of the bend, the angle it needs to bend, and the amount of straight pipe in between bends. All of this is done in 2-D for the time being.
I am currently using the Data Extraction tool in the same manner you describe it but only to count the parts that are being used to fasten together our rail.
How would I set up the Data Extraction to give me this pipe length? Would it be able to tell me the cut length for bent pipe?
