- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Im not familiar with the following product but I believe the feautre you are looking for is built into AutoCAD Plant3D. one would simply click on the line (and in the properties) to get the cut length and i believe it can be exported in excel as well. I realize this is a different application of pipping than you are using but it is there it might be in some of the other verticals.
I might hope over to the plant 3d forum and ask around if you dont get another answer here. https://forums.autodesk.com/t5/autocad-plant-3d-forum/bd-p/371
Another solution would be to use lisp or something along those line within autocad to calculate these lengths, but that will likely take some development.
To help me better understand what you are looking for could you describe the process which you are trying to automate.
CADnoob
