en respuesta a: chriscowgill7373
Chris, I finally found the 'New VP Freeze' button. The column had been narrowed to the point it was almost not visible. Unfortunately, that button was the same for the layer that doesn't appear in the viewport as for all other layers in the file.
Since I only need a PDF of the viewport for bidding purposes, I'm going to copy that layer into paper space on that viewport so it will appear in the PDF.
Thanks for your help on this anomaly. I'm going to close this thread to take it off the active list.
