john.vellek
en respuesta a: Anonymous
Hi @Anonymous,.
There are a few things that can be examined to remedy this behavior.
  • First take a look at Xrefs and nested Xref files to make sure that they are clean and stable <see article>
  • Check to make sure that you have installed hotfixes and service packs from here.
  • Move all the files to your local drive to verify that your network path to them is not the issue.
  • Verify all the locations stored in your file paths (in Options) are valid and can be reached. A bad path can cause some lag.
  • Take a look at Task Manager to see what else is running. Security software might be interfering
John Vellek
