nichkherbsman
en respuesta a: Anonymous
I think the problem is that the layer of the object is freeze in layer while you are in layout and inside the Model Space using view port.
The solution is:
1. Go to the layout.
2. Double click to the view port (that will make you go inside the model space using view port, make sure you lock the view port)
3. Go to Home, Layer > Look for the layer and see if the freeze is on/off.
See screen cast for more info.
NiCHKCiD
BIM Modeler
Technical Officer
Technical Designer
Sr. Draftsman
