john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
Open your Customize User Interface by typing CUI at the command line. Then select the command you have added to your palette. you will see the image at the top right. Select export and save to a known folder location. Once you have done this for each of the commands, you can then open the Tool Palette, rt-click each item and assign the exported images to the com
mand in the tool palette.
John Vellek
