ANDYPITT1573
en respuesta a: TheCADnoob
Hello, thanks for the responce.
CUI looks fine, I experimented with adding a tab, and certain panels are completely devoid of icons. I should be clear, not all panels are missing their icons. I attached another screenshot to show. Switching workspace has limited effect as if a panel is blank, then it appears blank in every workspace. That said the drafting workspace is only slightly affected, as only the block panel and all panels under the A360 tab are dead.
