nichkherbsman
en respuesta a: ramjan3N9ZA
Hi Ram,
The easy way to get the total length of multiple lines is to use lisp.
Here is the code:
(defun C:TLEN (/ ss tl ent)
  (setq
    ss (ssget '((0 . "LINE,ARC,CIRCLE,*POLYLINE,SPLINE,ELLIPSE")))
    tl 0
  ); end setq
  (repeat (sslength ss)
    (setq
      ent (ssname ss 0)
      tl
          tl
          (vlax-curve-getDistAtParam ent (vlax-curve-getEndParam ent))
        ); end + & tl
    ); end setq
    (ssdel ent ss)
  ); end repeat
  (alert (strcat "Total length of selected objects is " (rtos tl)))
  (princ)
); end defun
If you don't know how to use lisp, here is a link:
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-AutoLISP/file...
See also screencasts below.
Thank you. Guiño
NiCHKCiD
BIM Modeler
Technical Officer
Technical Designer
Sr. Draftsman
