ramjan3N9ZA
6868 Vistas, 3 Respuestas
Total Line Lengths / List command
 Hi
Is there any way to take total length of 5 or 6 lines in selection
Please help me
Ragards
Ramjan
Ramjan
imadHabash
en respuesta a: ramjan3N9ZA
I suggest to use addlines.vlx  or addlen that it may help.
Imad Habash
nichkherbsman
Hi Ram,
The easy way to get the total length of multiple lines is to use lisp.
Here is the code:
(defun C:TLEN (/ ss tl ent)
  (setq
    ss (ssget '((0 . "LINE,ARC,CIRCLE,*POLYLINE,SPLINE,ELLIPSE")))
    tl 0
  ); end setq
  (repeat (sslength ss)
    (setq
      ent (ssname ss 0)
      tl
          tl
          (vlax-curve-getDistAtParam ent (vlax-curve-getEndParam ent))
        ); end + & tl
    ); end setq
    (ssdel ent ss)
  ); end repeat
  (alert (strcat "Total length of selected objects is " (rtos tl)))
  (princ)
); end defun
If you don't know how to use lisp, here is a link:
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-AutoLISP/file...
See also screencasts below.
Thank you. Guiño
NiCHKCiD
BIM Modeler
Technical Officer
Technical Designer
Sr. Draftsman
Vinayv4v
Here is a LISP to find all lengths of selected lines or polylines. File attached. (Credits : Tee Square Graphics 1998) TLEN
(defun C:TLEN (/ ss tl n ent itm obj l)
(setq ss (ssget)
tl 0
n (1- (sslength ss)))
(while (>= n 0)
(setq ent (entget (setq itm (ssname ss n)))
obj (cdr (assoc 0 ent))
l (cond
((= obj "LINE")
(distance (cdr (assoc 10 ent))(cdr (assoc 11 ent))))
((= obj "ARC")
(* (cdr (assoc 40 ent))
(if (minusp (setq l (- (cdr (assoc 51 ent))
(cdr (assoc 50 ent)))))
(+ pi pi l) l)))
((or (= obj "CIRCLE")(= obj "SPLINE")(= obj "POLYLINE")
(= obj "LWPOLYLINE")(= obj "ELLIPSE"))
(command "_.area" "_o" itm)
(getvar "perimeter"))
(T 0))
tl (+ tl l)
n (1- n)))
(princ)
Cheers,
Vinay Vijayakumaran
