imadHabash
en respuesta a: Anonymous
Hi and Welcome to AutoDesk Forum,
SURFTRIM command trims portions of a surface where it meets or bisects a curve, region, or another surface. and you have only 3D SOLID objects which it's different of surfaces object, for that this command will not accomplish your need at this 3d solid object. i suggest to use SUBTRACT command HERE that will serve your 3d solid objects.from RIBBON you can found commands for SOLID and SURFACES (see image below)
Good Luck..
Imad Habash
