3473 Vistas, 4 Respuestas
Need Help with 3d Surftrim command
Hello everyone. I am new to the forum and I was hoping that someone could help me out with an issue I am having.
I can not seem to get the surftrim command to work on the object I am drawing and it is quite frustrating. I have seen several videos on youtube on how to use the surftrim command but I still can not get it to work with my drawing.
I have attached a drawing of the 3d object that I made. It is an automotive switch and another "testing" surface consisting of a slab and a couple of solids incorporated into it. I have tried the surftrim command on every object but it still will not work and I don't know why I am having this issue.
The error I keep seeing after selecting a object is "not valid object type" I am not sure why my 3d solid is not a valid object.
Can anyone help me out please?
Thank you.....
Etiquetas (2)
imadHabash
en respuesta a: Anonymous
Hi and Welcome to AutoDesk Forum,
SURFTRIM command trims portions of a surface where it meets or bisects a curve, region, or another surface. and you have only 3D SOLID objects which it's different of surfaces object, for that this command will not accomplish your need at this 3d solid object. i suggest to use SUBTRACT command HERE that will serve your 3d solid objects.from RIBBON you can found commands for SOLID and SURFACES (see image below)
Good Luck..
Imad Habash
en respuesta a: imadHabash
Thank you that solved my problem. It took a little time but I got it to work perfectly.Emoticono feliz
imadHabash
Glad to hear that Emoticono feliz
Imad Habash
mhogewind
I am trying to trim surfaces that I created using corridors/assemblies and I am getting the same same error. please advise
