apstevenson
495 Vistas, 5 Respuestas
TXTEXP problem with Z axis
I have a  survey from a total station with about 500 points in 3D, each with a point number as text. All these are next to the survey point and each has a Z value.
I need to import this data to SketchUp and SketchUp does not recognise the text. If I explode the text then it will be imported and I can see what number each point has.
When I run TXTEXP all the exploded lines move to Z=0.
Is there any way to get them to retain their Z Value?
Thanks.
ara_neresesian
en respuesta a: apstevenson
hi
for each text you have to put " ucs" to original point of that text and explode that text only.
you have to do it for each text.
I know this a long way but if you have to do this thing always you have to use autolisp app,
if you can run lisp file send me your dwg and I will write lsp for you and you can do it by your own.
but if not I can do it by my pc and resend to you .
ara_neresesian
hi
its down
you can use it
I attached dwg file
I hope its ok but there was  many text over each other .
by lsp I converted all of them to 2polyline there are  more than 150000 number.
enjoy it.
apstevenson
en respuesta a: ara_neresesian
Thank you so much, that is amazing!
I don't know much about lisps, could I be so bold as to ask for that too so that I can have a go myself and use it in future, as I will have other projects that will need it.
Again, thank you!
ara_neresesian
Sure I will send it to you
But let me to debug it.
it’s a little slow and not good for big jobs if you are not in harry I will fix it in next week (I need some time)
and when its down I will send it to you 100%
apstevenson
That would be fantastic. Thank You.
