03-31-2017
10:50 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-31-2017
10:50 AM
HI @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I tested your file and it seems to work fine on my side too. Please tell me, if you add a field in your drawing (not in a block) and set it to a date with a time in the format, if you use UPDATEFIELD after a couple of minutes does it update to show the new time? If this does not work and your fieldeval=31 then I suggest that you perform a Reset Settings to Default to see if that corrects the issue for you.
John Vellek
