john.vellek
en respuesta a: Anonymous
hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
It would be helpful to see the file if you can attach it to a post.
Things to check:
  • Try turning on all layers and thaw them.
  • If the text is visible in modelspace but not paperspace viewports then check the layers in the viewport to make sure that they are on and thawed (VPFREEZE)
  • If the text is annotative, check the current scale.
  • Turn ANNOALLVISIBLE=1 to see if they show up.
John Vellek
