03-29-2017
05:02 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-29-2017
05:02 AM
FYI: Those "DD" commands were deprecated years ago. They only work today because they can still be defined in the PGP file. But if you are using a custom PGP file, it's likely to NOT work, like this:
Command: ddptype
Unknown command "DDPTYPE". Press F1 for help.
The actual command name is PTYPE, or you can adjust the system variables PDMODE and PDSIZE.
@Anonymous - I've opened your drawing and inserted it into a new empty drawing as a an Xref. I do not get the circles. Can you also supply the parent drawing you are using also? Thanks.
