273 Vistas, 2 Respuestas
line width display
One of the layer display very thick after binding the x-reference. I tried to copy and paste to other drawing the line is back to normal, anybody can tell us what's wrong with the settings?
Tom
ara_neresesian
en respuesta a: Anonymous
hi
check the layer name of that line which is not normal go to the layers find the same name and change the layer width in that dialog box
but in your file I cant see any xref you must put the source file ,
in your file every things is ok ,or put some pic to explain more  I did not see that line
en respuesta a: ara_neresesian
Hi Ara
Thank you for your reply, the is binded and that particular layer that giving us problem is A-_ANOTGRID_E-. I check the layer before binding and it is still the same result.
Tom
