ara_neresesian
en respuesta a: Anonymous
hi
if in other pc it is working good check your system var it must be 31 if not set it  <<fieldval>>value   to 31 press ok
and regen your drawing ,when you down it must be ok
anyway send your original file which you made your first field dwg. I have to check your file
