marco.defina
392 Vistas, 3 Respuestas
Open dwg wrong AutoCAD and icon
i have the AEC Collection...When i open a dwg, default open with AutoCad MEP with icon of AutoCad P&I...
What's wrong??Emoticono frustrado
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
jggerth
en respuesta a: marco.defina
The smart way is to open the AutoCAD flavor you want to work with _fist_, then use the OPEN command to pick the dwg file you want to edit.
Jonathan3891
en respuesta a: jggerth
I agree with @jggerth, but you can set the default program by right clicking on the AutoCAD File > Open with > Choose Default Program.
Jonathan Norton
Blog | Linkedin
marco.defina
en respuesta a: Jonathan3891
Yes, ok, but the strange thing is that AutoCad MEP has the icon of the AutoCad P&I...
