- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi @wai1954,
It sounds like you have resolved your issue with the hidden lines.
If you want to explore further the Viewbase command I am here to help. I have seen some extremely large models captured in projected views very quickly with this feature.
I am not sure why you are only seeing shaded views but i can probably help you figure that out too.
I like to use Viewbase with some layouts and then conventional Viewports in others so I can take advantage of all the ways available to display the data.
I am currently working with AutoCAD 2018 and the Viewbase command is much more robust than in previous versions.
Let me know if you want help on any of this. Otherwise, please take a moment to Accept a Solution (even if it is your own) if your problem is resolved.
John Vellek
