874 Vistas, 4 Respuestas
Autocad 2015 with Windows 10 comptables?
Hello everybody,
may you can help me, i
work with Autocad 2015 on the operating system Windows 8.1.
Is Autocad 2015 compatible with Windows 10?
For my new notebook (OS) the graphics cartridges are not supported under Window 8.1.
Thanks for feedback!
Otto
en respuesta a: Anonymous
Hello MariaWillems8830 and welcome to the Autodesk community!
It looks like you are looking for information related to AutoCAD and Windows 10. Community members with similar questions found the following article(s) useful:
AutoCAD on Windows 10
AutoCAD system requirements
If you have recently upgraded to Windows 10 and are running AutoCAD 2016 please be sure to download AutoCAD Service Pack 1.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
john.vellek
HI @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
AutoCAD 2015 can be installed on Windows 10 as listed here in the system requirements. If you elect to use that older version you will need to apply all the updates for it to function properly.
If you want to explore current product, trial versions of AutoCAD 2018 can be found here.
John Vellek
john.vellek
HI @Anonymous,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post solves your issue or answers your question.
John Vellek
en respuesta a: john.vellek
Hi John Vellek,
thank you for your proposition.
Unfortunately, I had no time to try this out. I will test it this weekend, and then report it to you.
