03-20-2017
07:09 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-20-2017
07:09 AM
HI,
>> When i switch off F10, i lost my indicator to know which is 30 degree or 120 degree <<
you can turn it ON,there is no problem. the purpose was to discover the difference not more.also there is no need to know the angle since there is just three isoplane (Left,Top and Right).
>> and my ellipse also seem weird after drawn <<
when you active ellipse command use Isocircle option.
Command: ELLIPSE
Specify axis endpoint of ellipse or [Arc/Center/Isocircle]:
Q: does your main issue solved or not? ![]()
Good Luck..
Imad Habash
