- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
>> WHen I tried Viewbase, it would only give me a shaded view
Have you seen the options?
>> I could not get it to change so was not sure if what it placed there was linked to the model.
>> If the model was changed, I needed it to update the view as well as otherwise
>> there would be problems on installation.
Do I understand you correct that you are not sure if these views are updated when you modify the geometry in modelspace?
If so ... yes it is, it is fully associative with the basic geometry. When I modify a 3D-Solid in modelspace and go back to the layout, it's regenerated and show the new representation within a second (or a bit more depending on the complexity of your object).
...including all dimensions you have created on that view-objects.
I'm wondering for the short time you have spent to that command, it has so many details and settings, that needs more than just one start ![]()
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
