wai1954
en respuesta a: Alfred.NESWADBA
Ok, I think I have nailed it.
After much fiddling, it turned out to be in the 2D Wireframe option (the first one).
The option for 2D Hide - Occluded Lines where the colour needed to be set as desired, and then the linetype as desired.
WHen I tried Viewbase, it would only give me a shaded view that was inserted in paperspace. I could not get it to change so was not sure if what it placed there was linked to the model. If the model was changed, I needed it to update the view as well as otherwise there would be problems on installation.
I had been through the two links provided, but they did not reveal much.
Much simpler to let users know that if they wanted to set what was set through HLSETTINGS previously, that what I discovered should be done.
Thanks for the tips.
wai1954 (Ian A. White)
