en respuesta a: rkmcswain
Using the Screening 100%.ctb as an example, each of the colors listed ( 1 through 255) show a lineweight value as Use object lineweight instead of an actual value. If I create a drawing with 255 lines, all on the 0 layer, standard defaults on the layer manager, but assign each line a numbered color instead of by layer. When the lines are plotted each of them will have one of approximately 5 or 6 different lineweights, I want to know what lineweight AutoCAD has defined for each color. If they were all the same, all of the lines would plot the same. This is especially apparent when printed on a black and white plotter.
