- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I'm having problems with AutoCAD electrical 2016 today. I had clouds with question mark icons on all my icons.
I cuiunload ACAD.cuix and cuiunload ACADE.cuix and then cuiload acad.cuix and cuiload acade.cuix
then I did a profile reset.
Then did the cuiunload then load again. No luck
then I changed profiles. this profile shows the Icons but they don't work. if I click on the project manager folder, down on the command line I get "unknown command: aeproject".
If I click on the schematic tab then click on the Icon menu button, down on the command line I get "no function definition: ace_dlg_cip_chk"
I had this problem last year and got through it, it happened again.
any suggestions??
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
HI @Anonymous,
Did the Reset Settings to Default work for you? Can you logon as a different user to see if everything works?
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If you keep your old email correspondence, search them for what you did to fix it. (I depend upon mine this way).
It sounds like your AutoCAD Support File Search Path and/or your Customization Files paths got wiped out. This can happen if your locations are on a network share and the connection gets broken before AutoCAD is initially opened. If you save a backup copy of your profile you can use that to restore them after you get the network connection restored.
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
8.6.52.0 AutoCAD Architecture 2024
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Project Manager works now.
Under the projects tab
When I click on title block setup or title block update, nothing happens
Under the schematic tab
clicking on Icon menu doesn't do anything
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
What steps have you taken so far?
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
HI @Anonymous,
Did you also try logging on with a new user account? If it works there then that means that your profile is damaged in some fashion. If it doesn't work then I suggest a clean uninstall and then reinstall to fix the issues.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
We are a small company and don't have an IT dept.
Could I get someone to walk me through on the phone?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
You can schedule a call or try a CHAT from your account page.
If you have other users, have one of them try logging onto your computer to see if it works properly.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
Did the other user logon to your computer? Did everything work normally then?
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
So everything is working normally then?
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
