beyoungjr
en respuesta a: Anonymous
Blocks Blocks Blocks!
Your MLEADER, QLEADER, or even just exploded leader elements, can be dynamic blocks so that you can insert them and then tweak the lengths or positions as desired.  The TEXT you desire would exist in the BLOCK as ATTRIBUTES.  Those attributes could be aligned as desired, colored as desired, and even exist on separate layers if you so desire.  This might be one of the few instances that I would create a block or elements within on layers other than zero.
Do you see where I'm going with this?
Blaine Young
Senior Engineering Technician, US Army
